427435 wrote:
Again, the extensions below can't leak. There is NO pressure in them except when you are filling the inner dual or checking the pressure of the inner dual. Otherwise, the normal schrader valve at the wheel holds the pressure.
427435 wrote:
The best flexible extenders are these. There is a wire inside the hose that operates the inner dual schrader valve. Thus, if the hose breaks, no air is lost from the inner dual.
..But they can work loose where they're screwed onto the valve stem, and leak there. Thats how one of my extensions leaked, and made a tire go flat pretty quickly.
With solid valve stem replacements like DuallyValves, you pretty much eliminate that risk, potential failure point.
Will
