willald wrote:
427435 wrote:
Again, there is no pressure in the extension. If it comes loose from the inner dually, the worse thing that can happen is the extension falls off. The valve on the tire itself, is always closed unless you have put a pressure chuck or pressure gauge on the other end of the extension.
Maybe that is what I should have said to start with-----------the Schroeder valve on the inner dual stays there when you put this extension on. The valve isn't taken out like with a regular extension.
Thanks for the clarification, I must have had a brain lapse and did not realize they worked that way.
You're right, extensions like this would not have the risk of leaking, as long as it leaves the Schroeder valve on the tire closed (except when you put a pressure gauge on, like you said).
Would they reach far enough, though, to allow you to check air pressure without having to remove wheel covers? Could one of these be used for the outer dual, and be turned 180 degrees and pointed out so you could get to it (without removing a wheel cover), and still work when turned that tight?
If the answer is 'no' to either of those...then I'd still have to say the DuallyValves are the better choice. That is, assuming you can find a dually valve made for your tires/wheels. If not, an extension like this would definitely be the next best choice (and a lot less expensive, too).
Will
They were plenty long enough on my setup to both check and add air if necessary w/o needing to remove the wheel covers. I can check my outer dual by using a truckers double ended pressure gauge, also with the wheel cover in place.
