427435 wrote:
The extender is 9" long. If you wanted to use one on the outer dual, that should be more than long enough to make a "U" bend back to the outside.
..I wasn't concerned so much about its length being long enough to make the "U" bend back to the outside. Was wondering more about whether it would still function properly when held in that tight a bend?
Meaning, if you put an air chuck to it, would it push through to the tire's schrader valve and give you an accurate pressure reading, even though the extension is in a sharp 180 deg. U bend like that? Was it designed to be used that way?
It may well work OK, I don't know. I know for a fact thats not a problem at all with the DuallyValves, though.
Will
