HOOKUP's avatar
HOOKUP
Valve Extensions for 19.5" Dual Tires
Can anybody give me good place in Orange County Ca for installation of hard connected Brass valve extenders for my Baystar 3209?
  • I think he is talking about installing the hard extenders not the hose type. They are all one piece just longer run about 120.00
  • traveylin wrote:
    I have had the extenders and watched mechanics add air. Extenders are awkward and do not give a good impression of getting an accurate pressure reading. The last check, the mech simply took the hub caps off and was able to get excellent access doing the job much faster than fumbling with the extenders
    If applied correctly...you'll get the same accuracy as having your inflation gauge right on the valve stem.
  • I have had the extenders and watched mechanics add air. Extenders are awkward and do not give a good impression of getting an accurate pressure reading. The last check, the mech simply took the hub caps off and was able to get excellent access doing the job much faster than fumbling with the extenders
  • Any tire shop should be able to do it as 19.5 fit on the tire changers. Allen tire did mine.
