paullac's avatar
paullac
Valve Stem / TPMS 101 Questions
I've had past problems with leaking valve extenders. Basically a trip interruption each of the last 2 years now. We are taking a 2 + week trip this year so want to try to minimize the risks as much as possible. Here's what I want to do. Am I missing anything?
- Replace the existing valve stem / aftermarket extender combination with an all in one system like Tire Man or Dually Valves. I figure going to an all in one system will take away at least some chance for leaks. Plus, I believe I need an all metal system for TPMS. That said, does anybody have contact info for Tire Man as I can't get their website to open?
- Possibly add a TPMS system as well. TST507 seems pretty well liked on RV forums. There's also the one below on Amazon that is rated a little higher & is a little cheaper as well.
http://www.amazon.com/Flow-Through-Sensor-Pressure-Monitoring-System/dp/B005JREMLM/ref=sr_1_3?ie=UTF8&qid=1433251021&sr=8-3&keywords=rv+tpms
Does anyone have any thoughts or suggestions before I go down this road?
Thanks!
  • Bobbo's avatar
    Bobbo
    Explorer III
    Here is the tire man link:
    http://tire-man.iwvisp.com/products.html
    I have these valve stems on my RV, and like them. Kit #2-6F was the one that fit my tires.
    I do recommend a TPMS. I have one. I got it after getting back from driving over 1,000 miles to find an inside rear dually completely flat. I can't rate the TPMS in your link as that is not the one I have.
