DSDP_Don
Sep 10, 2013Explorer
Bill.....Those are for coaches that are using one piece stems (no extensions). They won't do anything for your extensions. Your extensions should be bolted to the center hub.
I disliked the look of the extensions on my 22.5 Accurides, plus they made it hard to polish the rims. My extensions never leaked, but I replaced them with a long valve stem. I see people recommending the "Dually Stem" which I think are over a $100.00 dollars a pair. You have to be crazy to pay that. I went to a local tire store who had 8" valves that fit my rims for $11.00. I later found them online for $8.00.
I didn't like the looks of the plugs you posted either, so here is what I did to support my long stems. I made a support for the stem out of a piece of thin aluminum. I mounted it over the studs between the inner and out duals. This is the template:
This is what it looks like installed:
On the outer wheel, I just turned the original metal stem around, but wish now that it would have been replaced with just a short straight stem:
38,782 PostsLatest Activity: Sep 10, 2026
