CooncatzExplorerMar 11, 2016valve stem points inside on rear dual tires?I purchased a 98 Four Winds Class C in December and it has been parked since I brought it home. The snow is about gone so I wanted to check the air in the tires; but the valve stem on the rear outsi...Show More
want-a-beExplorerMar 12, 2016I had the same problem! I just loosen the valve stem and turned it so I could get a gauge on it.Good Luck
Related ContentReplace insulation inside heater column.Worn inside TiresInside tire valve extensionsFilling inside rear tiresInside Tire Wear?
