5thWheel_of__Fo's avatar
Sep 25, 2019
Inside Tire Wear?
Need thoughts. Have owned a lightly used 2005 DRV Mobile Suites 5th wheel since 2012. Fabulous rig. Replaced original 7 yr old Goodyear GST's when purchased in 2012 with the same tires, that looked great by the way, and no problems with our new ones and very even wear. As a precaution (6 yrs later), we replaced them with same tires in 2018. About the same time, we also replaced the original Dexter Hub and Drum Assembly 7000 lb Nev-R-Lube Axles, Dexter Nev-R-Adjust Electric Trailer Brake Assemblies, and Dexter Shock Absorbers.
After 16 mos and ~ 10-15k miles, we have now discovered that ALL 4 of our Goodyear GST's have very significant wear on the inside of the tires. What????? Never a problem in 7 yrs?!?
Best I can figure, either:
1) hubs/drums were not properly installed,
2) hubs/drums were defective from factory, or
3) axles have failed or been damaged
Since we've owned this rig now for 7 yrs, I seriously doubt we've overloaded it weight-wise as nothing much has change since.
Appreciate any thoughts you all may have. Thanks!
