Frznrth
May 22, 2017Explorer
Rear inside tire wear. Bent axel?
Hi
I have a 4 year old 30' bullet. I noticed that the inside of both rear tires are completely worn out - a bit on the outsides too but not nearly as bad. The fronts are wearing fine fand only maybe 1/3 gone. I read this can be from a bent axel. I do see a wow in the axle but have also been told that some bend is normal. True?? I don't remember doing anything that would have bent an axle. Replace the axle?
Am I good to replace the tears with new ones or do the fronts need to match?
Thanks for the time.
