j-d
Mar 12, 2016Explorer II
We have Borg Dually Valves HERE
Great fit, durability, customer service.
Many have been fortunate to find parts that work at truck tire shops and some have found shops that will customize stock valves to fit RV needs. Some have home-brew rigs to get caps off, gauge on, air in, etc. Good for them, but the point is that good valves solve the air checking problems. And, they prevent slow leaks as well as catastrophic failures. Think of this:
1. BEST is a custom one piece heavy duty brass or steel valve
2. Extenders are OK if they're Braided Cover AND Airless, connected to METAL valves
3. NEVER put ANY extension/adapter/extender on RUBBER Valves
4. Replace Rubber with Metal (any kind!) at first opportunity
5. Class C's and probably everything American with 16, 16.5 or 19" wheels have .453" valve holes. Big truck wheels have .625" holes, so that reduces some of our choices when we go to truck stops and HD tire dealers.
Thing I like about our Borg Valves is that I can check and inflate anywhere. Bicycle pump, convenience store, interstate truck stop, doesn't matter. I carry a dual-footed gauge like shown above, but I can check just as easily with a free Discount/America's Tire gauge.
OH! Also added "Air Through" valve caps. Those rascals keep dirt out, provide a secondary air seal, and no unscrewing. Just push the gauge or air chuck onto them. They go by Gator, Crocodile, V2B. Available Amazon, NAPA...
I can check six tires in as many minutes and find that they still don't need air after months. We have Bridgestone R250's from Discount Tire. Between those tires, Discount's mounting, and the Borg Valves, adding air is about a twice-yearly process. Mostly when the seasons change and affect tire pressure. Drudgery became Pleasure.
