Ivylog
Jan 07, 2018Explorer III
Welcome to the Dark side, the DP side and some of us are fairly outspoken. Pretty sure in your cross country trip you are close enough to large cities to get OTA TV...local channels. If I figured correctly, seven changes in less than 30 days. Guess I'm with the tech guy...you've abused the system enough with all your changes so once every 30 days from now on for you.
The solution is to learn how to use your OTA external antenna and how to program your TV channels when you change locations...not that difficult and should take less time than what you spend calling with a new address. Like I said, Welcome to the Dark side.
