wallynm
Jul 24, 2014Explorer
hitch failure
More information on hitch failure.
Simple correction I learned the hard way. EVERY SAFETY FEATURE DID NOT FAIL!!! The safety chains were installed incorrectly as the safety chains should be attached to the frame of the motor home and the vehicle being towed. In order to be safe the safety chains must be attached independently of the hitch and base plate.
Failure to follow this procedure will result in what is described by the OP in that hitch failure or base plate failure will not be protected.
DannyLeininger wrote:
A dear friend sent me this photo of his Jeep Cherokee which recently became detached while driving on I-95.
The story goes that they were driving down I-95 when a motorist drove up beside them madly honking his horn. Not understanding what the motorist was trying to tell them the wife looked out her side view mirror and saw their Cherokee visible in her mirror. Screaming at her husband (the driver) they watched as the Jeep hit the retaining wall and very slowly came to a stop. They were astonished realizing the miracle that the car never crossed the 4 lanes of heavy traffic and that they were going about 25 mph when things finally came apart.
EVERY SAFETY FEATURE FAILED!!! The Air Force One braking system never actuated...Really! Upon inspection, both Base Plates had come loose from the car taking with it the bumper and Break Away mechanism and all the attachments including the Safety Cables and the Air Force One connections (which is why it failed to actuate.) All bolts for the Base Plates were gone...either sheared off or came loose on their own and everything was still attached to the towbar, now dragging behind the motorhome. I assume there was some poor Base Plate installation practices involved here as the system wasn't more than 18 months old.
The moral of this story is to regularly inspect your towing gear. Shake things from time to time to see if things move that shouldn't.
The amazing thing is, only damage was metal...the car was totaled due to age and mileage.
Take this as a reminder to CHECK YOUR STUFF!!
38,782 PostsLatest Activity: Sep 10, 2026
