RCMAN46
Oct 27, 2012Explorer
If you did not have the problem before the new tires then I would also bet you have a bad tire. If they are radials there most likely is a broken steel belt in one or more tires. This can happen when they are mounted and they use a strap to get the bead to set and over tighten the strap.
