davron94 wrote:
rooney77 wrote:
Google death wobble and you'll get more information than you can shake a stick it.
You said it only occurs when braking, that leads me to believe you have warped rotor or a bad caliper. Take it to a mechanic, not an RV place, and have them check it out for you.
This issue only occurs after the front end has been jacked up on the stabilizers and then only when braking. then after a few miles on flat road, it goes away. wouldn't a rotor or caliper problem show itself more often?
Missed that part. Well I'd say it's got to be in the suspension, ball joints are the first thing that come to mind but as has been mentioned control arm bushings could also be at fault. It's unusual that it's resolving itself though.
