MountainAir05
Oct 01, 2014Explorer II
RodHatter wrote:
MountainAir05
If the Air is set to max its recirculated right?
Thats where I ran it for about 10 miles to the house.
Ill check it again and see if I can get an actual temp.
That is what I used and ensure the fan is set at high. and around 1800 rpms at lease. Moving is even better.
Having sealants put in can a lot of issues, (opening a can of worms here). That said, if you are only keeping for short time, and the cost of a new coil is close to $1000, then that the customer choice. I have a different set of gauges for those units. Sometimes very hard to flush out and get it all. The exp block and evap have some very small orifices but the block is not too pricey. Also check the heater control valve, when hot. Hot on engine side and cold Coil side.
If you can get a outside, inside temp then the output in the center vent.
38,782 PostsLatest Activity: Sep 10, 2026
