Hank85713's avatar
Hank85713
wandering front
A couple of years ago I read a road test on setup similar if not the same as I have. I cannot find the article so Need to see if anyone else has encountered and cured.
In the article they talked about light front end and wander. On this 2012 winnebago aspect I have the same issues. Rear bags aired to 50psi and did help some but the front is light and I am thinking it needs an improved or dual setup steer stabilizer.
So has anyone else encountered and how did ya deal with it? van has just under 6000 miles on it.
Thanks Hank
  • j-d's avatar
    j-d
    Explorer II
    Hank, What are your:
    Axle Weights
    Tire Pressures
    Coach Length and Wheelbase
    Aspect Model Number
    Alignment Numbers esp. Caster and Toe
    And:
    Any chassis/steering upgrades so far?
    Are you towing a Vehicle or Trailer?
    Alignment-Wise: On the E-Series, Road Wander is a result of too little Caster and not too much. Mid-range spec for E is around +3 and we're finding +5 tracks much better. The F-Series must be different because if an E went less than +3 let alone negative you'd have to tow it or park it.
  • Are you towing a trailer or car on a dolly?
    Have front end alignment checked?
    Steering damper?
  • Hank, sounds like a typical case of front end alignment issues. I didn't see the article or even own the same rig you have but my 08 F550 was doing the same thing and I had the caster set to about -1 degree ( I think that is correct) and it took the light or over steer out of the rig. It drives straight down the road now without having to over correct constantly. I have also setup several off road Jeeps with big axles, big tires and complicated suspension geometry and if the caster is set too far positive the Jeep will wander all over the road. It is called over steer and is a symptom of incorrect caster. Consequently if the caster is too far negative it is very difficult to steer and make corrections, this is under steer. Hope this helps you out.
