SuperSteer (painted blue) is a product of Henderson's Lineup. The BlueOx TigerTrak (black) is the same bar, different color, only slightly different part numbers. I believe Brazel's track bar is also the same bar in red.
I considered Roadmaster and Hellwig for Sway Bars. Hellwig, from SDTruckSprings, is about half the Roadmaster price from the outlets that carry Roadmaster. The Hellwig rear bar does NOT require drilling. I compared it with Roadmaster and actually prefer the design and installation of the Hellwig. The Roadmaster front bar has a more elegant end link bracket setup than the Hellwig. Prettier. For the lower price, I went Hellwig, and it has not worked loose.
Both bars have the same spec for the steel they're fabbed from, and both use the same diameters, which are 1-3/8" Front and 1-1/2" Rear. A coach with a set of either brand bars will handle and track better on the road. It will ALSO sit steadier on the campsite. I was not expecting that improvement and it just jumped out at me the first time I got on the Kwikee step.
