JJCruiser wrote:
Both brackets are now installed but I hit a roadblock when I started to install the bar itself. It requires a couple of 1 1/8 inch wrenches to install. I don't have anything that large. I will need to pick up an open end wrench and a socket for the torque wrench. It appears the bar is going to line up well with the brackets and with good clearance between the differential and the gas tank.
Great! Keep us informed with your continued progress. Once you have successfully finished, you'll be promoted to the resident expert. :)
