RJL's avatar
RJL
Wanna bring a golf cart and a Jeep towed
We're selling our vacation home in SW Fla and plan on using our Challenger for future vacations of a month to 6 weeks. I'm thinking I might want to buy a golf cart to bring along with my Jeep towed. Is there a way to do this? Maybe something to put the golf cart on and then hook up the Jeep.
  • Simplest solution is to dump the golf cart unless needed for a disability. Get a bike rack and bikes. Perhaps some battery powered bikes.
    Couple of problems you're up against.
    1. Double towing. Hit or miss on not getting pulled over in states that do not allow such.
    2. Towing weight limits of a Ford F53. The Damon is a nice coach but the F53 it's built on is pretty much limited to 5K lbs towing and maybe even less depending on which chassis model. Your at 4,500 lbs for the Jeep add in potentially 1500 lbs for a light trailer and golf cart puts you beyond the chassis limits. Trailing the Jeep and golf cart will put you well beyond the limits of the chassis.
    No worries taking one or the other but the only way to safely get by with both is if the someone else drives the Jeep with the golf cart behind it on a trailer.
  • 24' tailer.... 14 feet for the jeep, 10 for the golf cart.
    do not extend beyond 60 feet total.
  • dodge guy wrote:
    Look for a rear dolly or platform. Some are attached to the MH at 2 points (2 receivers). And then you can tow off of the platform. You could also get a swivel wheel trailer which has 2 wheels that swivel for backing. You could attach this to the Jeep, they are not considered a trailer.
    Well,
    The OP's not say what model "Jeep" they're intending on towing but, if it's a Wrangler, you cannot tow it on a dolly. Jeep specifically condemns that in the owners manual. Now, I have no idea what the OP's motorhome is rated at for towing but, one might look into an aluminum flat bed trailer that both might fit on. Then, you'd only have to figure where to park the trailer at in many camp grounds.
    Scott
  • Look for a rear dolly or platform. Some are attached to the MH at 2 points (2 receivers). And then you can tow off of the platform. You could also get a swivel wheel trailer which has 2 wheels that swivel for backing. You could attach this to the Jeep, they are not considered a trailer.
    double towing is illegal in some states. an enclosed double deck trailer comes to mind but is likely too heavy for the MH chassis to safely tow. may i suggest that before you embark on this plan that you know and thoroughly understand your Damon's various weight ratings (GCWR, GVWR, GAWR as well as the actual rolling weight of your loaded MH and the items you want to tow. your rubicon likely weighs over 4K pounds by itself.
    be safe.
