MrWizard
Oct 15, 2017Moderator
unless you have (2) independent hydraulic systems, one for the jacks, one for the slides, the slides will need to be retracted
IF your slides are 12vdc motor gear driven, that is NOT Hydraulic
then check the pump reservoir for a large plastic cap/nut
level has too be checked in the hydraulic reservoir
with jacks retracted
putting fluid in the system with slides or jacks out , will result in over flow (possible damage) when retracting
you are in the wrong place
the reservoir on this Safari is in the engine service bay, curb side rear of RV
please post a picture of the pump ?
IDK where yours is at, it should be Labeled
Power gear levelers, have the reservoir at the pump
38,769 PostsLatest Activity: Dec 31, 2014
