dougrainer
Oct 16, 2017Nomad
donnyB7 wrote:
I finally had some time to check the fluid level. I had to extend the slide out behind the drivers seat to get access to the HWH system. There were four horizontal cylinders that looked something like oil filters. They were attached to a metal block that had an oil plug above each of the four cylinders. Do I have to check each one or is there another place where the fluid level is checked?
NO NO NO!!!! Do NOT remove those plugs. The reservoir is the large BLACK CAN mounted to that solenoid assbly. 1 easy twist off filler plug mounted in the center. Doug
38,769 PostsLatest Activity: Apr 03, 2026
