jseines
Dec 09, 2013Explorer
Warning signal or ?
My Class-C 1995 E350 Motorhome has a problem that has me scratching my head...problem is with engine running there is a high-pitch squeal coming from somewhere in the rear bottom 1/3 of the coach...when engine is stopped the squeal stops...when I turn on the ignition key you can hear the fuel pump pressure'up then stop...when engine is started the high-pitch squeal starts...I have crawled under the coach trying to locate and to'date no-joy finding the problem...any and all suggestions will be gladly accepted...I'm tool and mechanical savvy, this one has me running...I may be overlooking something that is simple & minor ...Thanks/John
