mmriddile
Jun 24, 2014Explorer
I have a Splende Combo Washer/Dryer in my coach and I use it all the time. However, it takes some adaptation. If I had a choice and especially if I was going to be spending a lot of time in the coach, I would go the the stacked washer/dryer. I have also had the stacked unit in several homes and it is pretty much like using a regular washer/dryer except the loads are a little bit smaller. With the combo, the loads have to be very small--like the top sheet and 2 pillow cases or 3 bath towels. Then, when the sheets come out of the dryer, they are very wrinkled. Any clothes that are dried in the dryer will be very wrinkled because they go from being tangled up in the wash cycle right into the dry cycle. Less is better with the combo. Because I want to reduce shrinkage, I typically air dry most of my clothes on hangers on a rod in the shower stall and I have a small electric fan that I set on the floor of the shower stall, tilted up. With the glass shower door closed, this creates a wind tunnel that dries the clothes quickly and since they are constantly moving...no wrinkles. Either way, having a washer/dryer in your coach is wonderful. Keeps you out of the laundry mat!
