louiskathy
Jun 24, 2014Explorer
Stackable. (I'd never go with a combo).
We've been full timing since 2005.
I've had a Splendide stackable washer/dryer since 2007.
They have been used 3 to 5 times a week since Feb 2007.
Very dependable... only had one broken belt in the dryer and that was because I washed a rubber backed rug in it... and it got jammed between the drum and the side of the drum in the dryer. (I tossed the rubber backed rugs - I won't wash them in my machines.)
I do use 20 mule team borax in every load. ( a couple coffee scoops of it.)
I use HE liquid laundry soap ( Go easy on the amount use use... 2 TBLSPOONS of HE laundry soap is plenty.) Use liquid fabric softener. (NEVER use dryer sheets in the dryer.)
Dry the gasket.... check the gasket around the door for gunk and KEEP CLEAN. There should be drain holes in the rubber gasket that you can easily see.
Keep the washer door open so the inside can dry when not in use.
