Executive45
Jul 13, 2013Explorer III
You have a short inside the junction box where you plug the washer in. Open the box with the BREAKER OFF, and check the wiring. Chances are one of the wires has come loose. Check for burnt areas around the receptacle. Replace if necessary. A regular household duplex plug from Home Depot will work.....Don't forget to turn the breaker back on after replacing/repairing the plug.....Dennis
38,771 PostsLatest Activity: Apr 15, 2026
