Racine96
May 12, 2019Explorer
I have 311FS that did not come with it installed. If you remove the rear panel in the closet, you will see that everything needed is already installed. However, I installed a Splendide vented. I did a hole in the outside wall. It works fine. You need to put the water heater off in order for it to work. I turn it off while using the washer. The unit comes with a separate valve and connection for the used water, so you need to be hooked on a site. It does not go the grey tank. If you get under your unit, you will see it. Look at the link below and you will see photos of it installed and the exhaust vent.
http://www.forestriverforums.com/forums/f230/my-first-class-c-134789-15.html
38,777 PostsLatest Activity: May 19, 2026
