lafrentz wrote:
you can leave the door open till the cows come home but the grey water seal will get a musty smell.
But that does not mean that letting it dry out as much as possible after each use doesn't help.....because it does.
If there is a removable "tray" where things like soap and fabric softner get put in, it can retain a fair amount of water after a load too. It probably can be taken out easily and dumped after each use.
Check the owners manual for recommended cleaning. When we did that, we found a clean-out door with a screen behind it. YUCK.
And finally, every 10 loads or so run it empty with a quarter to half cup of chlorine bleach. Too much bleach can actually damage stuff if it is a reduced water design......which most front loaders are.
