Bill_Satellite
May 19, 2014Explorer II
They are great if you give them a call. Very helpful. I had a similar issue and it turned out to be a loose wire on the timer inside the housing. If you call you are going to need to have the washer out so you can check things out with them so you might as well pull it out and take a look yourself. The top comes off easily and you will be able to see the connections and controller from there.
