Branson_N_Tucso
Jul 31, 2020Explorer II
They build a fram around it so it secures it when going into the spin mode. I'm pretty sure that if you remove the out side frame you will see the the water line . The hot and cold water lines will lead you to it. Now on my 2003 Fleetwood the fram is held in by 4 screws. Some time the fram just snaps in or pulls out.
Good luck.
Good luck.
38,783 PostsLatest Activity: Sep 09, 2026
