dougrainer
Dec 25, 2019Nomad
You should NEVER have the Washer/Dryer circuit thru an Inverter. The Washer/Dryer can be run with the Genset and Genset should be used for the washer /Dryer. The main thing to remember, is, make sure your Gray Tank is empty before you leave. Depending on the Gray tank size, it may limit how many loads you can do. Most RV's state to leave the Gray valve OPEN when using the Washer, to prevent a sudden overflow into the RV if you fill the Gray tank too fast. It is standard CTA wording. Doug
I have NEVER seen a WD wired thru an Inverter. If it is, it would have been done by a customer, not the OEM.
