dougrainer
Dec 26, 2019Nomad
time2roll wrote:
I can't imagine any issue with a sine wave inverter or running the washer in general... or the dryer for that matter. Grey tank would be my only concern.
The issue is simple. You can only run so many hi amp appliances thru an Inverter. When NOT Inverting, you have pass thru 120 power going thru your Inverter. There is a limit to how many appliances can be run thru an Inverter. That limit is the SIZE of the Pass thru Inverter 120 breaker/s AND its Transfer relay. Yes, no RV Washer/Dryer will overload a 2000 watt or larger Inverter. But why make the Inverter work that hard? Run your Genset. It needs regular running also and most RV'ers never run their Genset enough anyway. Doug
38,782 PostsLatest Activity: Sep 20, 2026
