homerbw wrote:
We have parked our motor home on a lot which has a sewer discharge located approximately 300' away. I was considering installing a macerating system to pump our waste to it but not sure if the distance is to far. What do those of you with experience say about this idea? Can a macerator push waste this distance. The distance is a gentle downward slop.
If it is downhill all the way then it should be just fine. I would use "at least" a 3/4" water line. Everything runs downhill just fine as long as there are not "ups" along the way.
