OK my friends, the job is done. I needed to move the motor home closer to the house to get my 3/4 inch hose to reach the sewer drain which turned into a nightmare because the ground was wet and we got stuck in mud up to the axle. I tried using the rear hydraulic jack to lift the tire in order to put something under the tires and the Jack sunk into the ground at its full length. I spent two hours digging it out then filled the hole and called for a tow. I guess the sewer issue was not my biggest problem compared to that. Well, the hose and macerator is doing a fine job so thank you all for your responses. Total length of hose needed was 75'.
