Bought a FloJet macerator pump. I used it today for the first time. Pumped out into a toilet. Will NOT do that again. No issues, but **** it stinks! You think the son of a Plumber would know this!!!
OK, the toilet was in the shop, not the house, I am smarter than that! My plan for home pumpout, the reason I bought this, is to install a feed to my septic tank that runs lose enough to my parking spot to be able to dump here instead of worrying about finding a dump on the way back.
My plan is to put spring clips on the power wiring and pull power off the genset. I may run the wire permanently in the spring. Going to get a 3/4 or 1" hose long enough to reach my septic tank at home, might get two shorter hoses. Will definitely get a different color hose, probably Black.
