ccxnola's avatar
ccxnola
Water Fill Concern - How To If No Pressure???
All of my previous rigs had a gravity fill opening for the water tank.
While I have had my current rig for several years, I just now came to realize that the ONLY way to get water into the tank is via connection of a fill hose from a pressurized source (home, campground, etc).
I can access the tank in a compartment, but there is no external fill available.
I am trying to find a capped fitting that I can install at the top of the tank in the compartment so if I need to get water into the RV from a bucket, I can do so.
I cannot get to inside the tank, so the fitting will need to 'glue' to the top of the tank since there will be no way to secure it from the inside.
Any thoughts?? Fittings and source?? Thanks!!
  • Use a 12V water pump to transfer from the bucket to the pressure hose connection?
