cavie
Nov 22, 2019Explorer
1st, why are you putting antifreeze in the FW tank? If the tank was full the antifreeze is running out the overflow/vent tube. Stop filling! If you don't have a pump winterizing kit buy one. $15.00. It's a t fitting, a valve and a 2' hose. it allows you to suck antifreeze out of the jug straight into the piping system using your water pump. It goes between the pump and the FW tank. should not take more than 3 gals.
