Gundog
Nov 22, 2019Explorer II
cavie wrote:
1st, why are you putting antifreeze in the FW tank? If the tank was full the antifreeze is running out the overflow/vent tube. Stop filling! If you don't have a pump winterizing kit buy one. $15.00. It's a t fitting, a valve and a 2' hose. it allows you to suck antifreeze out of the jug straight into the piping system using your water pump. It goes between the pump and the FW tank. should not take more than 3 gals.
My manual says to do it that way it worked last year. I have not heard of the kit you are talking about but I will look into it.
You don't fill the whole tank with antifreeze it has me drain the fresh water tank and the water heater then put 5 gallons of antifreeze in the fresh water tank the problem is the fill port is leaking somehow and it is leaking rather than going into the tank.
