olfarmer
Nov 22, 2019Explorer II
cavie wrote:
1st, why are you putting antifreeze in the FW tank? If the tank was full the antifreeze is running out the overflow/vent tube. Stop filling! If you don't have a pump winterizing kit buy one. $15.00. It's a t fitting, a valve and a 2' hose. it allows you to suck antifreeze out of the jug straight into the piping system using your water pump. It goes between the pump and the FW tank. should not take more than 3 gals.
I would buy that kit. My Winnebago came with that set up and it works great. No need to put antifreeze in the fresh water tank. I actually winterized mine with 1 gallon this year but I ran another gallon through just to be safe.
