stargirl96's avatar
stargirl96
Water Filter Woes
I finally found the water filter behind an access panel in the rear storage bay of our Jayco Greyhawk ME. It is very inconvenient as you have to lay on your side to remove it. I've tried to use the spanner wrench to unscrew the filter housing, but no luck. So I will probably end up having to take it to an RV dealer to have this simple thing done and spend $100 or more. Would it be better to have the RV mechanic do a bypass valve rather than pay to have him remove and install water filters once or twice a year. I understand you can put a water filter on your hose in place of a whole house filter. Thanks for your help.
  • You could have someone pull the element out of the filter housing and then reinstall the housing. Then use an outside filter. If you don't pull out the element, it will slowly plug up and you will have no water flow.
  • If it were me I would bypass the water filter and as you said use an inline filter on your water hose.
  • I have another question on this topic. Can we just leave the water filter where it is and use a water filter attached to our hose?
