becker's avatar
becker
Water Filters - need help
I have a 2008 Monaco Dynasty Motorhome. I am trying to change filters in my water system. I opened up the canisters and there was no filters inside either one of them. I bought the coach new and this is the first time I am changing them so I assume they were never there originally.
My question: When you first open the maintenance door and first view the filters, which one is the primary sediment filter and which one is the secondary carbon block filter (the one on the left or the one on the right)? Because it is so congested where the filters are, I cannot ascertain which is the water in flow and which is the out flow. The manual says the "Five Micron Sediment Filter" should go into the first stage and the "Five Micron Carbon Block Filter" goes into the Secondary Filter. The problem is I don't know which is which.
Can anyone who has a coach like mine help"? Thanks.
Becker
  • Just for the sake of argument...I don't have water filters. Never did. Well, my 2001 motorhome came with a under-the-kitchen-sink filter, but the first time I winterized my mh I had to remove it, installed the supplied "jumper"pipe...and never put the filter back.
    Travel from NJ to Florida numerous times, and NJ to California 4 times. Sometimes the water tastes different, but never had problem with getting sick or any "deposits" (say from "hard" water or anything else) in the water system.
    If filters give you peace of mind, go for it.
    Just FWIW.
  • Turn the pump one with the canisters removed. The water will come out of the first stage.
  • Can you remove one of the hoses to the filters ? If yes, do so and turn on the pump. if water comes out of the hose, then that filter is the primary...if no water comes out then it is the secondary.
    Hope this helps.
    Ron
