Neumann wrote:
After reading all the comments I have to offer this.
I have a Atwood model 10-E water heater. It's gas/electric.
My literature on the heater calls the red light a lockout condition and will light red when a lockout occurs. There are a number of conditions that will trigger the red light to come on. When the light comes on there is a problem in the heater and the literature explains what to do to turn it off.
So, I guess other heaters work different so all I can say is read your literature on your heater to see the proper way it should work. Who knew.
Hal
That is correct HAL.
But you have standard Atwood panel in your FLeetwood
Winnebago uses a 'OnePlace' centrally located control center/monitoring panel with lighted switches
Both water heaters work the same.....
