lrash
Apr 01, 2015Explorer
water heater boil over
I dewinterized my Cross Country 383 FWS Class A and filled water tank and lines. Turned on water heater with electric heater element. About 4 hours later blow off valve had water running out and water was boiling - steam out of water heater . I did not have one of the bypass valves turned correctly. Turned off water heater. Turned valve and got water from spigot that would scald you. Does this sound like a thermostat failure or could my have the bypass valve turned wrong have caused this? Thank you for your comments
