Old-Biscuit wrote:
n7bsn wrote:
Well, I would need 12 gallons as opposed to 2
I understand that at least one of the water-heater makers recommend against RV antifreeze in the tank
OP isn't using anti-freeze just blowing lines out
I drain and blow lines only.
Because of water in bypass line I do open bypass valve while draining (leave cold and hot valves open) so that section doesn't have any trapped water.
Sounds like a good idea. I only use antifreeze in the traps and toilet so no danger of getting antifreeze in the hot water tank. Thanks for the suggestions.
