dougrainer wrote:
Chris Bryant wrote:
When you install it, are you making sure the loop winds up vertical, and not horizontal?
OK Chris, I will play. HOW and WHY would that be a factor? How would you make sure it is either? Unless it is a OLD 4 bolt in system, it would be difficult to thread it in and make sure of the orientation. I would suspect they are NOT using Atwood parts. Doug
Doug, that's how I have been taught by the factory training. If you look at the element, you will see it is indexed by the writing- easy to align it correctly.
If the loop is korizontal, trash short the element.
