tropical36 wrote:
grannyapple3 wrote:
We have an Atwood 10 gallon elec/gas water heater. We are on like our 4th element in probably 2 years. We make sure tank is full before turning the electric switch on but we are going through these things like crazy. Any ideas why we are constantly burning the elements up???
Thank you
Are you normally in one place for long periods of time and if so, what's the voltage? Also what is the voltage rating on the replacement units and I would like seeing at least 130vac for having some longevity.
These things usually last next to forever, unless without water or in an air pocket, so would always run a little water through the tank, if sitting without use for long periods and before turning it on.
Come on tropical, electric water heaters are resistive loads, voltage has no bearing on longevity
