tropical36 wrote:
hanko wrote:
tropical36 wrote:
grannyapple3 wrote:
We have an Atwood 10 gallon elec/gas water heater. We are on like our 4th element in probably 2 years. We make sure tank is full before turning the electric switch on but we are going through these things like crazy. Any ideas why we are constantly burning the elements up???
Thank you
Are you normally in one place for long periods of time and if so, what's the voltage? Also what is the voltage rating on the replacement units and I would like seeing at least 130vac for having some longevity.
These things usually last next to forever, unless without water or in an air pocket, so would always run a little water through the tank, if sitting without use for long periods and before turning it on.
Come on tropical, electric water heaters are resistive loads, voltage has no bearing on longevity
Why not hit it with 240vac then and just to see how long it will last?
You might just be reading me wrong here.
Light bulbs are resistive loads, as well, so try seeing how long one of them might last at 125vac, if only rated for 115vac.
Heavy duty incandescent bulbs, as they call them sometimes, are rated at 130vac and will last much longer, with various voltages put to them.
Another example are my night lights outside my home, that I run at half voltage and haven't changed one of these bulbs since inception, 13yrs ago. I also used to have some 250vac bulbs that would last next to forever and found some uses for them, as well.
Not sure what these water tank heating elements are rated for, but hopefully for at least 130vac.
your first post said that you like to see AT LEAST 130 volts, so I think you pretty much meant a low voltage, not 230 volts.
