Hank MI wrote:
grannyapple3 wrote:
I would like to thank everyone for all of your reply's. Hanko I agree with the crappy Mexican or Chinese parts but I would think we might get lucky an get a decent one somewhere along the line. I am going to check thermostat but it seems to work fine on gas and I agree with cdl2 about the relief valve
Atwood heaters have an ECO, thermal cutoff, for both the propane and electric side. If the temp gets too high on electric the electric ECO will open and cut voltage to the element. Once tripped, like a circuit breaker, it has to be manually reset. If the thermostat fails the ECO will open. So I don't think your thermostat is the problem since you haven't said anything about the ECO. This assumes no one has bypassed it.
The ECO has no manual reset. It will reset once the tank temp drops. Doug
