dougrainer wrote:
NOT ON YOUR MODEL. That is the operative statement. YOUR model has the OLD style rear system. The OP may have the NEW style system with the Tstat and ECO on the ourside, which controls BOTH LP and 120 operation. NOT in the back. You still have to access the back to replace the element. We really need the OP to respond with their Model number. They may have an old style as 2003/2005 was when Atwood changed. Doug
Well I guess my statement was no more correct nor incorrect then yours since it depends on which model they have. As the MH is an 03 like ours it may have the manual reset ECO. In any case if the unit was overheating due to a failed thermostat the ECO should cut power and prevent the element from overheating.
