rv_bear
Jan 25, 2017Explorer
water heater hot not hot at faucets
More than likely a lot of you already know this but two days ago our water coming out the faucets was not hot, so at first I checked the water heater element. This is on a 2004 Southwind with a 10 gal. Atwood heater. It was not the element I called Atwood they thought it might be the check value after replacing the check value still the same problem. Then I called Fleetwood, they asked was the outside water faucets in the water bay on, I had forgot and I had left them 0n and they were still on and just because water wasn't coming out it affects the water heater so the temperature is way down. I never knew this would happen thank you Fleetwood Customer Service.
