Golden_HVAC
Dec 21, 2013Explorer
My RV is 17 years old. The water heater still works, but has cracks in the aluminum tank, that cause it to drip a bit. So I would say you can get 16 years out of them.
What savings will you get by replacing the heating element? Propane is about $3 per gallon where I live and electric to run the heating element about $0.10 per KW. It takes 22 KW to make the same amount of heat as 1 gallon of propane, so you would save about 80 cents compared to burning a gallon of propane in my area. Since my 11 gallon propane tank will last 4 weeks full timing in the summer, my guess is the refrigerator used 1/2 that propane, and then the water heater 4-6 gallons in 4 weeks, or about $5 per week. Either way, it is not worth it to say "I will save $40 a year in propane by replacing the electric element."
But buy and have a $465 water heater installed if you are happy with that decision. The heating element is about $45, and as you said will take a bit of time to install. You are not sure that it will be leak free once completed, however most of the time it all installs quickly without problems.
I would just leave it alone, and burn propane for the next 6 years, replace it then, if you have not already traded it in on a newer model.
Fred.
Fred.
38,777 PostsLatest Activity: May 20, 2026
